Transmission Leaking Between Tranny and Transfercase
There is a small leak between the transfercase and transmission, is there a seal there i can replace?
either way yes there are seals there. Dave |
No i can't tell forsure, but it has my tranny mount soaked and my front driveshaft at the transfercase damp as well. I just blew my tranny i think so we will find out soon
please let me know. I have puddling of trans fluid at same location... there is an output seal on trans, a gasket in between the housings, and input seal.... I should be doing mine later in the week.
BC Diesel
In both cases the t/c is likely coming out which is not that difficult, were are you guys located, I may have a BD recommended dealer in your area.
Dave |
I am in Ottawa Ontario
I guess there is no output seal, only the housing gasket and input seal on t case. Also there could be a crack in the trans by the piston
Well this is what she looks like
![]() the parking pawl popped out, i dont know, but it seemed like this is how the spring goes? So far it works..... And I havent seen a leak yet
