Transmission Dropped into Neutral?
I was driving today and when i pulled into the driveway ( no throttle applied)
my transmission dropped out of gear and wouldnt shift into anything but park. I shifted a bit then i had drive for a few seconds and lost it again. I parked the truck and started it an hr or so later and it worked fine reverse and forward. any ideas?? |
Hey just an update, now it wont go into gear at all just the rpm change when trying to shift ... sometimes it will go into gear for a few seconds but i will need to push the pedal quite a bit to get it to move and it barely dos then slipps out again
Fluid Level?
Fluid level is fine and a nice red colour, i did notice a bit of a smell but not a strong burning smell or anything when i smelt the oil
You wouldnt happen to know which tranny is in my truck would you its a 2001 f250 4x4 lariat
99% sure it has to be a 4R100
Thanks i was pretty sure that was the one as well
Yes, You definately have a 4R100. But unfortunately I know very little about those transmissions.
Free Bump! |
I'm guessing the transmission is toast , by the lack of responses
I'm trying to get ahold of my son, he had something familiar with his, but can't remember what the "cure" was. Will repost when I find out.
