02 f-350 overheating transmission - Ford Powerstroke Diesel Forum
Old 02-02-2012, 06:03 PM
recently my diesel transmission has started to overheat after driveing a fairly short distance. the temp rises rapidly. so far i have checked the fluid level and tried adding lucas transmission additive with no help. will a transmission flush and new filter help or will that be just wasteing money.
Old 02-02-2012, 07:03 PM
GAS GAS is offline
check the bypass valve on the passenger side of the transmission.
It will be closed at start up to warm up fast, then open to flow atf though the cooler.
when you drive it and it reads hot, check the temp of the out let and return lines on the transmission, if they are both cold you have found your problem. A new valve assembly will cost about 45 or 50 bucks, or it can be bypassed with kits sold at various venders.
Old 02-03-2012, 03:20 AM
bypass valve location
if it is the bypass valve will that be inside the transmission or will that be an external plug in sensor valve?
Old 02-03-2012, 04:29 AM
GAS GAS is offline
it is external. It is the tube that connects the outlet with the inlet of the cooler lines. I will try and post a picture of one in a little while
Old 02-03-2012, 02:43 PM
thanks
thank you for the input turns out the culprit is the converter so im lookin at a rebuild job and a new heavy duty converter
Old 02-03-2012, 06:10 PM
GAS GAS is offline
well that sux! sorry to hear that.
Old 02-03-2012, 06:21 PM
Powerstroke Techie
Says who ?
