Help diagnose noise - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-02-2012, 11:41 AM Thread Starter
01Crewcab7.3's Avatar
Help diagnose noise
Ok so as long as I have owned my truck there has been a "grinding" noise if you let the clutch out with not enough throttle. Like I said it has always done it and I am just trying to figure out what it could be so I can get it fixed. I plan on replacing the clutch here soon with a new flywheel and the works. Hopefully it will fix it. Thanks in advance for any possible help.
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #2 of 4 Old 02-09-2012, 09:35 PM Thread Starter
I have been doing some research, would this be a failing dual mass flywheel??
Tim
post #3 of 4 Old 02-10-2012, 07:09 AM
Brian 444's Avatar
We don't have dual mass flywheels...I think they quit using those on the OBS with ZF5.
If it is only when engaging the clutch it could be a throwout bearing I suppose.
You sure it isn't just gear rollover?
Brian 444 is offline
post #4 of 4 Old 02-10-2012, 09:05 AM Thread Starter
Sorry, apparently I'm dumb. What is gear rollover?
Tim
