01 zf6 front oil seal - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-17-2012, 06:14 AM Thread Starter
Hi. I got my mtr and ZF-6 trans apart and I have a small amount of trans oil on the inside of my bellhousing. I am pretty fussy when it comes to fluid leaks and would like to know what is involved with a new front trans seal? Thanks.... Artie
2001 F350 4X4 ZF6 PSD
artieb is offline
post #2 of 3 Old 01-18-2012, 06:26 AM
Freedombyforce's Avatar
I'm changing mine, but I have the transmission taken apart. I wouldn't think it would be hard to change it together though. Just take your Pivot Arm/Throwout bearing off, then there is 3 or 4 small bolts that hold the slide for the throwout bearing. Take that off, dig out the seal and replace with new. Just be careful not to damage the shaft or housing. I've got the specs on the seal at the house and can get them if you need it.
BTW.... Ford wanted $25 for the seal. I took the measurements to my local bearing shop and got one for $4.
2002 F-250 CCSB
ZF-6 Swap
Manual T-Case Swap
K&N Intake, CCV Dumped, Riff Raff Boots
Foil Delete, AIH Delete, EBPV Delete
Wicked Wheel
Farm Boy's 5" Straight Pipe with 6" tip
PHP's Tunes with 6 pos
Hutched 51 gal Titan Tank
Iron Bull Bumper with PIAA 510's and Strobes
Warn M12000, Retrosolutions LED's inside and out
2011 Tailgate -Taillights - Front Ford Emblem
17" Fuel Octanes with ProComp Extreme AT 35's
Freedombyforce is offline
post #3 of 3 Old 01-18-2012, 11:17 AM Thread Starter
I spent 25 at the dealer, easy replacement though, thanks, Artie
artieb is offline
