Shift flare issue - Ford Powerstroke Diesel Forum
Old 11-22-2011, 10:25 AM
Illiana Chapter Director
Shift flare issue
Got a friend with a 99 PSD and it has a shift flare when going into O/D. Shifts perfect in every other gear. He took it to a shop to have the trans. looked at for the issue and had the trans. rebuilt. Still did it when reinstalled. The guy that did the rebuild ended up having it out 4-5 times trying to fix the issue. Ended up putting a reman trans. in it and still has the problem. I told him to take it to a dealership and have the PCM updated just in case it was a software problem and still has the problem. Anyone out there had this issue and know of a fix? Thanks guys.
Old 11-23-2011, 04:50 AM
Anyone??
Old 11-23-2011, 04:54 AM
Almostdunfukinwidit
Software or wire harness issue. Chip it see if it goes away.
Old 11-23-2011, 05:02 AM
I was thinking software issue, that's why I suggested having it reflashed which didn't help. Never thought about a wiring issue and have no idea where to start. He's wanting to chip it but didn't want to mask the problem.
Old 12-23-2011, 01:26 AM
What is a shift flare?
Old 12-23-2011, 08:24 AM
Feels like it shifts into neutral before going into the next gear. You will see your RPM's jump when it does it.
Old 12-23-2011, 12:04 PM
Thanks for the reply!
