AUTO XMISSION QUESTION - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-18-2007, 12:35 AM Thread Starter
rex
HELLO,I HAVE A QUICK QUESTION, PLEASE. I'M PRETTY NEW TO THE SITE, BUT I'VE LEARNED A TON OF THINGS VERY QUICKLY. THANKS TO EVERYONE.
MY 2001 F-250 LARIAT 4X4 ,7.3, ( 102 K MILES), FROM A STOP, WHEN I START TO ACCELLERATE, IT MOVES OUT, BUT TRANNY OR TC SEEMS TO "GRAB" (LIKE I FEEL A SLIGHT THUD) A SECOND LATER. OTHERWISE, RUNS GREAT, PULLS MEDIUM LOADS OF SHAVINGS & HAY, HORSE TRAILERS, ETC. IS THIS NORMAL ? LIKE TO KNOW, I THINK I HAVE AN EXTENDED WARRANTY.
BY THE WAY, BOUGHT A SENSOR ON LINE & WILL INSTALL & LET FOLKS KNOW IF LITTLE STALLS GO AWAY.
rex is offline
post #2 of 5 Old 08-18-2007, 12:48 AM
HardLuck Case of the Year
Ditty's Avatar
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
I'm not going to lie...I know almost NOTHING about Auto trannys....BUT....I'm almost 100% someone will be on w/ in a few hours to help you out!
Ohhh...and WELCOME to the .org!!!
DITTY
Brisco:-White 2000 F-350 PSD CrewCab/SRW/LongBed/4x4/6spd Manual/HUGE Powerstroke.Org Vinals!
Favorite Mods: Baby-seat mod/Girlfriend delete/6pos on Xtreme!
Repairs since bought: both batteries/alternator/3 transmissions/4 clutches/entire front axle/new steering stabilizer/power steering pump
Still broken: cracked windshield/all glowplugs/glowplug relay/4WD still out/trailer harness no power
Current Best: 16.149@84.13MPH (Est.7800lbs)
Ditty is offline
post #3 of 5 Old 08-18-2007, 02:22 AM
if your saying it takes a second to enguage after you press the accellerator. It sounds like your tc to me.
tubilcane is offline
post #4 of 5 Old 08-18-2007, 09:57 AM
duct tape & zip ties
bigcountrysg's Avatar
Either your TC is going or First Gear clutches are going. If you do alot of towing and heavy hauling I suggest you look into a triple disc tc and heavy duty clutch packs.
I also suggest you take it to a transmission shop that knows how to build these transmissions for our trucks.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #5 of 5 Old 08-20-2007, 06:07 PM
If the truck moves when you press the gas and you just get a little thud try lubricating you slip joint splines on the fwd end of the rear drive shaft. I had the same problem and it went away. easy to do just mark the shaft and you will be fine. Heavy duty bearing grease will do the trick.
99 F-350 7.3 L PSD 4x4 cc LB Lariat Black & gold AIS intake, 3 guage pillar, 6.0 - 31 row cooler, 203* therm. w/ billet housing
01 F-250 5.4 L 4x4 4:10 Rear end sc SB Lariat True Blue & gold ( SOLD )
country2 is offline
