2003 f250 7.3 rear main seal myself - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-24-2011, 05:28 AM Thread Starter
Hi, im new to this site a mechanic said my rear main seal is leaking and a piston needs to be changed in cylinder 6 i was thinkin about changing the rear main seal myself how hard would this be also how much would it cost to fix the piston and my hpop is new and the rings are good . Any insight or tips would be helpful thanks
Hankins is offline
post #2 of 3 Old 05-24-2011, 05:56 AM
aawlberninF350's Avatar
Welcome to the org!
"Rear main seal" leaks are something else 95% of the time. Any oil leak on top of the motor will run down there. Get a good flashlight and look carefully in the valley for leaks. Might have to clean it first. Prime suspect locations are turbo pedestal, hpop. Lay a pad on the motor to be not quite so uncomfortable while you are up there.
Also, what is wrong with that piston?
Happy hunting!
02 F350 Lariat 4X4 CCSB SRW 4R100 w/FTVB.Mishimoto 6.0 IC.26 row 6.0 trans cooler.6637.WW.RiffRaff FrxGen2/Plenum inserts/AIH delete/boots.Hutch.Harpoon.50 cent.Isspro EVs.Walker BTM.DP Tuner.AC mod.Mile Marker 449ss.Fumoto.DDM HID 55w 4500k.Bilsteins.Dieselsite Coolant Filter.
Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats. - HL Mencken
aawlberninF350 is offline
post #3 of 3 Old 05-24-2011, 06:07 AM
usnavyad's Avatar
Feedback Score: 3 reviews
check you turbo pedistal o ring or the hpop lines very coomon prob i have never seen a rear main seal leaking
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
