6 speed no gears.... - Ford Powerstroke Diesel Forum
post #1 of 21 Old 02-27-2011, 08:17 AM Thread Starter
Hi Im new.
I just purchased a 99 6 speed with the following problem. You can start it, and with it running you can put it in any gear you want and it wont move. Clutch / no clutch it doesnt matter.
Has another had this problem before? I have never even heard of it.
I will be pulling the trans ASAP but i figured I would ask around first
onlyn8v is offline
post #2 of 21 Old 02-27-2011, 08:37 AM
jlarsen's Avatar
this might be a stupid question but does it have a drive line?
2002 F350 Crew cab Lariat
Power Hungry Performance Gryphon- Custom Tunes
GTP38R
Bellowed Up pipes
NON-EBP Pedistal
4 Inch Lift and 35 inch Goodyear DuraTracs
AFE Stage 2 Pro Guard 7
MBRP 4 inch turbo back
GDS High flow power outlet
Zoodad mod
Tranny cooler
Trans go shift kit
Airlift Bags with compressor
1996 extended cab 4x4 Powerstroke TOTALED
5 speed, heavy duty clutch
AFE stage 2 intake pro guard 7 filter
4 inch Diamond Eye turbo back exhaust
cat delete
TW chip
jlarsen is offline
post #3 of 21 Old 02-27-2011, 08:38 AM Thread Starter
Yes, its all there and DS spins when truck is rolling. Does not spin when in gear
onlyn8v is offline
post #4 of 21 Old 02-28-2011, 11:56 AM Thread Starter
This hasent happened to anyone else?
Im really chomping at the bit to pull this trans out...
onlyn8v is offline
post #5 of 21 Old 02-28-2011, 03:07 PM
Id say that the clutch is shot. I toasted the clutch in my dads truck when I was a kid and it did the same exact thing.
The chance that the actual gears are all gone is slim to none. Good nes is its a fairly quick and inexpensive fix.
Jim
2000 7.3l 4x4 6sp
DIY intake
4" exhaust
6pos by Dyno Proven
Wicked wheel
160cc
Honey Badger jr
custom clutch
Auto Meter Z series gauges
jimmyp is offline
post #6 of 21 Old 02-28-2011, 03:12 PM
I agree Clutch has grenaded
loopygroup is offline
post #7 of 21 Old 03-01-2011, 11:05 PM
this just happen to me and the clutch grenader
20highpowerstroke is offline
post #8 of 21 Old 03-02-2011, 04:17 AM Thread Starter
Great, Thanks for the responses. I was pretty sure that was the problem, but just wanted some opinions. Ill be ordering a Valair clutch today I think. (SB too much $ for me)
onlyn8v is offline
post #9 of 21 Old 03-02-2011, 06:26 PM
if the flywheel has any signs of getting hot you should think about getting it machined or replace it, or you will get chatter on engagement.
post #10 of 21 Old 03-03-2011, 01:03 PM
Another stupid question. The transfer case is in gear (4hi, 2wd, 4low) also?
Effreem is offline
