e4od 1997 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-14-2007, 04:32 AM Thread Starter
e4od 1997
just rebuilt e40d in 1997 f-35o 1st gear ok 2nd gear ok noshift into 3rd or 4rth more or less free wheels rebuilt converter installed
tracy is offline
post #2 of 5 Old 07-14-2007, 04:38 AM
The Fat Mod
Logan's Avatar
I can't help ya, but I am sure someone will be able to give ya a hand shortly.
Logan is offline
post #3 of 5 Old 07-14-2007, 06:02 AM Thread Starter
BY THE WAY IT IS A DIESEL
tracy is offline
post #4 of 5 Old 07-14-2007, 06:04 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Im not a tranny expert but maybe a solenoid is screwy
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 5 Old 07-14-2007, 06:01 PM
Do you really want to know all the things that could cause that??
I'll give you a few.
Missing or missplaced ck balls, Loose bolts on v/ body, solenoid pack, missing or cut rubber seal diredt drum, cracked ring direct drm, loose or missing center support bolt, wrong v/body gskts, loose bolts over accumulator body, stuck accumulator shif valves, etc,etc
ipz2222 is offline
