I think it's slipping
If I get on it in 1st and when it goes to 2ed it feels like it's slipping in the shift like you can fell it somewhat shift but doesn't fully engage for a sec. If im in 2ed and step on in there's no slipping. I feel it in my 80 and 120hp tune from php. How can i fix this do I need a shift kit or a valvebody or what.
What is "it"????
It=tranny...
Did you figure "it" out? I was thinking of getting some PHP tunes.
Yea I need a shift kit or a valve body but I just haven't had time to get one. So I just don't get on it until it shifted into 2ed. Get the tunes from PHP you won't be disappointed.
Mine used to slip between 1-2 under WOT but not under 75% throttle. A tugger kit or VB with the proper drilling should sort you out so long as you do not have worn out clutches etc. I thought I had too much wear possibly but that was 100k miles ago when I addressed it and it still shifts fine. It just needed a little more pressure during the 1-2 with my setup I guess.
First off how many miles are on your transmission? Slip causes heat, heat causes wear. Wear, heat and slipping equals.......I think you know where Im going.
I just rolled 140k but its been stock for 134k
"it"??? Year , ,make,, model,, 2wd,, 4wd????
