just rebuilt but locked up in forward - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-04-2011, 10:53 PM Thread Starter
truck is a 1999 early crew cab dually 7.3L 2wd
i just rebuilt my 4r100 with alto red eagle clutches and transgo tugger torque convertor is a billet with sonnax parts inside ..
it will go in reverse and stop no problems but when in any forward gear it will shut off the engine if i come to a complete stop we have pulled the tranny and changed the torque convertor and still didnt solve the problem .. does anyone have any ideas?? it is shifting perfectly in forward gears ..
i bought the truck with a blown trans ..front pump seal poped out and burned the trans so i dont know any other history other then that .. no check engine light or blinking od light
wildhorse1966 is offline
post #2 of 5 Old 02-08-2011, 03:33 PM
bad front pump!!!! Has crossleaks.
ipz2222 is offline
post #3 of 5 Old 02-08-2011, 08:56 PM Thread Starter
i am suspecting the pump but it doesent explain why it does it only in forward and why would it shift perfectly if the pump was loosing pressure .. probally going to pull it tomorrow
post #4 of 5 Old 02-09-2011, 03:34 AM
The pump is not just a pump. It is also the pressure regulating system and has the tcc lockup control valve in it. Pressure leaks from one circuit to another and causes the tcc to apply when it's not supposed to.
ipz2222 is offline
post #5 of 5 Old 02-15-2011, 10:41 AM Thread Starter
so i ordered a rebuilt pump and installed it .. that solved the problem thanks alot for your help
