ZF6 Rear Seal - Ford Powerstroke Diesel Forum
post #1 of 1 Old 01-27-2011, 06:35 PM Thread Starter
99BEIGEPOWERSTROKE's Avatar
ZF6 Rear Seal
I have a slight leak of tranny fluid thats coming from where the ZF6 tranny and transfer case connect. I originally thought it was the transfer case cause tranny only has like 20000 miles on it but I swapped out transfer case with a newer one and it didnt fix it. The transfer case fluid was also a little low when I checked it but that could have just been. I had swapped it out last summer and it still leaks. It has to be coming from tranny so is there a seal in the rear of the tranny that can be replaced easily without removing tranny? If so where can it be bought and how does it get changed?
Thanks
1999.5 FORD F250 SUPERDUTY 4X4 EXT CAB
7.3L POWERSTROKE DIESEL
6 SPEED
SWAMPS 175/146 SINGLE SHOT INJECTORS
SWAMPS TUNING
6" AUSSIE STACKS
AFE INTAKE W/ PRO GUARD 7 FILTER
VAN TURBO
4" SUSPENSION LIFT
315/75/16 BUCKSHOT MAXXIS MUDDER TIRES ON STOCK WHEELS (WINTER TIRES)
16X9 MOTO METAL 951 BLACK WHEELS (SUMMER)
COWL HOOD
99BEIGEPOWERSTROKE is offline
