1999 f250 speedo not working o/d light flashing please help - Ford Powerstroke Diesel Forum
Old 01-25-2011, 07:38 PM
Couple of days ago i started the truck and when i started to drive the speedo was not working and when it shifted into 2 or 3rd the o/d light started to flash it shifts smooth. So did alot of research and people said to change the abs/vss on the diff so i did that nothing happened. Do you guys think i should change the oss which is 50 bucks from ford part# F81Z-7M101-AA. Also 2 days ago randomly the speedo worked and o/d light stopped flashing and i thought everything was fine then it happened again. I need some help guys.
Old 01-25-2011, 09:46 PM
Check the wires to the VSS, sounds like one is broken.
Old 01-26-2011, 05:17 AM
How should I check it?
Old 01-26-2011, 05:52 AM
i checked the wiring harness coming off the vss with a voltmeter and got a reading of 4.9v is that what its suppose to be?
Old 01-26-2011, 06:14 PM
Please need help and info I have done alot of research but nothing helpped.
