NEED HELP ASAP!!!! NO 2-3 or 3-4 shift - Ford Powerstroke Diesel Forum
Old 01-23-2011, 02:55 PM
Exclamation NEED HELP ASAP!!!! NO 2-3 or 3-4 shift
well my od planet took a crap on me so i pulled out everything from the front pump to the intermediate shaft and replace everything that was bad, i put it all back together, now the trans wont shift from up from 2nd into any other gear, i have reverse, 1 and 2 in drive and i have manual first and manual second.... i am lost as to where to start, i have no flashing o/d light , and i checked all of the connectors on the trans, the only thing that i can think of is i could have damaged the pump gasket and/or the input speed sensor, but i doubt that would show the symptoms im having.... anything helps
Old 02-01-2011, 03:49 PM
You need to know if the computer is commanding the shift. If it is, then pull the front valve body. The shift valves are located there. Probably sticking.
Old 02-01-2011, 05:29 PM
well according to my chip it was shifting but the trans it self was not, so i pulled the valve bodies to find some warped valves and i ordered new ones and it shifts into every gear like a dream now
