99 F350 246k miles clutch just went out no sign no sounds - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-17-2011, 10:06 PM Thread Starter
Got off the freeway and with clutch engauged could not throw into gear had a puddle of dot 3 fluid underneith tranny and slave was leaking so replaced both master and slave bled them so no air bubbles clutch pedal got stiff everything seemed great then started and no clutch. Any help or just replace clutch thanks. 246,000 miles only replaced water pump and altenator 99 f350 super duty
steveO99 is offline
post #2 of 3 Old 01-19-2011, 07:19 AM
Zaairman's Avatar
Quoted: 12 Post(s)
I don't know squat about the ZF6, but I think there's a plastic piece that likes to break in clutch linkage (shift fork maybe?)... Either that or c'mon, you have 246K on the truck. The clutch has to go out eventually.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 3 Old 01-19-2011, 08:26 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Are you sure you've cured the original problem though..... (a bad slave AND clutch failure would be unlikely at the same time)
The slave can be a Bitc h to bleed, get someone else to work the clutch pedal while you watch the fork. Make sure you've got full throw and it pivots with pressure not just moves-back.
The best way I've found to get a good bleed on the slave cyl is to force fluid In from the bleeder and Up to the master (the air then works With you by rising as it wants to anyway)
NoRalPh is offline
