Truck wont shift in to park - Ford Powerstroke Diesel Forum
Old 01-16-2011, 02:10 PM
Send a message via AIM to 350dieselsmk
Hey Guys, Looking for info about adjusting shifter cables. mine has always ha slop in it but bow it has gotten to the point where i cannot **** it into park. I haven't looked under the truck yet because we just a banger snowstorm but if anyone has dealt with this before it would be great.
Thanks
Will
Old 01-16-2011, 02:54 PM
Powerstroke Techie
Take the shroud off of your steering column and look at the shifter bushings and make sure the tube isn't cracked. Also look at the bolts where the cable mounts to the bottom of the shifter.
Old 01-17-2011, 05:57 PM
Check on the side of the tranny were the shifter is attached and check for small pebbles between the shift bracket and pan. I had the same problem with mine this last fall.
Old 01-18-2011, 04:56 PM
is it possible to adjust the cable and take slack out of it if that's all it is?
Old 01-22-2011, 03:10 PM
Powerstroke Techie
no, if there is slack that means that something is worn and needs to be replaced.
Old 01-22-2011, 03:40 PM
Real Men Love Jesus! <><
chec k the bracket bolts directly under the dash on the steering column. mine were loose and it wouldnt go into park. almost backed themselves totally out! takes a star bit, number 32 maybe? I forgot.
