Pulling Tranny right now.. Does the startes bolts go through tranny case??? - Ford Powerstroke Diesel Forum
Old 01-09-2011, 06:45 PM
I am pulling my tranny to replace my converter, I pulled all the bell housing bolts but can't seem to break it lose. Do the starter bolts go through the tranny case? I pulled the bottem starter bolt and it seems short
Any help would be great
Old 01-10-2011, 07:46 AM
bump............................
Old 01-10-2011, 07:59 AM
Send a message via AIM to jhaddox
did you get the converter bolts?
Old 01-10-2011, 10:24 AM
six bolts through the bell and you dont need to pull the starter
Old 01-10-2011, 03:20 PM
It's real common for the dowel pins to stick in the trans case. Alot of wiggling to get it loose.
Old 01-10-2011, 07:11 PM
Changed the converter and it will still not lock up
Do y'all know where the TC solenoid is???
Old 01-11-2011, 04:20 AM
Is the computer commanding tc on. If it's not , you can change all the parts you want and it still won't lock up.
Old 01-11-2011, 08:36 AM
Look up the lock up switch, you can lock it up at idle and stall the truck.
Old 01-11-2011, 03:32 PM
I want to recap. My converter would not lock up, It gradually went out until it would not lock up. So i replaced the converter. It would still not lock up on the way home (40 mile) Today I unprogrammed back to stock, Drove 3 miles, Programmed back to FAST and the converter locked up at 46mph then 5 seconds later unlocked and stayed unlocked.
Pulled P0743 P0603 P0741.
