gas pedal super sensitive?
Whats going on? driving down the road 25 or 55 bumps on the road vibrate foot and pedal is so sensitive it surges rpm up and down.
tps could be acting up? that's my first guess.
where is that located and what does it look like?
Your TPS is actually at the top of the "gas" pedal and it's been a known fault but I'm not sure if your symptoms are typical if that failure.
I would suspect it too, maybe you could give it a good look for corrosion at the connector or "wiggle" it while running???? |
I just had my tranny rebuilt (AUTO) and this is one of the reasons i had it done, this sympton. Thanks for the info, called tranny shop and he said TPS too! Sounds like something i can do.
