Manual tranny fluid suggestions - Ford Powerstroke Diesel Forum
post #1 of 15 Old 12-19-2010, 10:00 AM Thread Starter
I'm replacing the rear casing on my 00 ZF6 transmission and will be refilling it with fresh fluid when I'm done. Any suggestions on what fluid to put in it and about how much it holds. Thanks for any input.
Tim
2000 F250 7.3 PSD, 6spd, 4X4, Ext. Cab Pickup
tdarty77 is offline
post #2 of 15 Old 12-19-2010, 03:30 PM
The owners manual should have that info.
ipz2222 is offline
post #3 of 15 Old 12-19-2010, 03:44 PM
7.34ever's Avatar
Quoted: 2 Post(s)
Feedback Score: 9 reviews
^^^I agree with that guy but pretty sure it's fully synthetic atf. Wierd I know but I've recently changed fluid in my '99 F450 at work and that's what it took. Cant remember how much tho
12TH Man
Live in WA or OR??? Check out these links.
7.34ever is offline
post #4 of 15 Old 12-19-2010, 04:28 PM Thread Starter
Unfortunately I didn't recieve an owners manual with the truck so I'm pretty much flying blind on this one. Atf fluid, that is kindof wierd. Thanks for the replies guys.
Tim
tdarty77 is offline
post #5 of 15 Old 12-19-2010, 04:37 PM
7.34ever's Avatar
Quoted: 2 Post(s)
that's what i thought too. i'll check my 07 manual. hold on
12TH Man
7.34ever is offline
post #6 of 15 Old 12-19-2010, 04:42 PM
Yep - its ATF in both the tranny and t-case. I just did it this evening; used Royal Purple...$$$$$ but it makes all the difference.
2000 F350 SCLB
SteveH is offline
post #7 of 15 Old 12-19-2010, 04:47 PM
7.34ever's Avatar
Quoted: 2 Post(s)
Ok the manual in my 07 says 5.8qts of Motorcraft Mercon ATF with Ford part number/spec XT-2-QDX/MERCON. possibly not the same but that's what I can give ya. good luck
12TH Man
7.34ever is offline
post #8 of 15 Old 12-21-2010, 05:57 PM
atf or gear oil
use atf or heavy duty gear oil wont matter much either way, park truck on level ground undo plug and fill it till fluid runs back out.
bjg8599 is offline
post #9 of 15 Old 12-30-2010, 05:06 AM
2000 f-250 7.3
GotDiesel85's Avatar
Send a message via Yahoo to GotDiesel85
putting atf in a manual tranny will significantly shorten the life of the tranny. ZF 6speed manufacturer calls for synthetic 10w30 motor oil. i use royal purple bcuz of its superior longevity and cooler operating temperature
DerekBob 2000 f250SD,
apr studs and mains,
FRx, HPx, 38r,
SP boost fooler, 6637, zoodad
HD clutch,
Bigger stix and nozzles, airdogII,
Terminator T-500 HPOP, Snow stageII,
PHP FU2, 4"tb 6"tip,
ISSPRO's(boost, pyro),
fog lights, bedliner,
4" block kit, 315/75R16 General A/Ts
GotDiesel85 is offline
post #10 of 15 Old 12-31-2010, 06:15 AM
sniper_101's Avatar
Running Mobil1 Synthetic ATF in my 00' ZF6. Mine took near 7 liters(qts), but I had my trans out so the cooler lines most likely drained out a bit.
2000 Ford F350 XLT - Supercab Shortbox - twin stick
1988 GMC Sierra
1994 Ford Ranger
2006 KTM 525 EXC-R - steet legal supermoto/dirt bike
sniper_101 is offline
