Transmission Questions... - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-17-2010, 08:39 AM Thread Starter
Question Transmission Questions...
I've pulled the transmission out of my 2001 7.3l F250, and am installing a Ford rebuilt automatic on Sunday. I have several questions though...
* Despite bold 14point warnings in the owner's manual NOT to use Mercon V, my local ford dealer said that's what comes in it and that's what they use. Anyone know if that's true? Mercon V says specifically not to use in transfer cases, but that's what the dealer told me to put in it as well. Help?
* Anyone use a second cooler in addition to the factory one? While I'm replacing the factory cooler, I could add a second one somewhere. Several of my RV owner friends that pull race cars say they do this to help with tranny life.
* I've heard of transmission temp gauges that plug into the OBDII port. Anyone have any advice? I'd like to put a guage in it so I can monitor what's going on.
MarkBMC is offline
post #2 of 11 Old 12-17-2010, 03:12 PM
Castrol Merc V is fine. I would get a larger cooler for sure. I would also use a Autometer gauge with the probe in the pressure test port.
FordNutz is offline
post #3 of 11 Old 12-17-2010, 03:22 PM
Scangage II ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool and will help you out with the EOT / ECT
DieselFord is offline
post #4 of 11 Old 12-17-2010, 04:06 PM
I wonder how accurate those are? I don't see where it monitors trans temps. Have you used one before?
FordNutz is offline
post #5 of 11 Old 12-17-2010, 04:34 PM
dusted4eva's Avatar
Send a message via MSN to dusted4eva
I would replace the trans cooler with the 6.0l cooler. Bolts in place just need the adapter kit.
Ford 6.0L Powerstroke OEM Transmission Cooler
I've got one as you an see in my sig. I also use Amsoil transmission fluid, in fact my entire rig consists of Amsoil fluids. I also have the trans filter system
2001 7.3 SuperDuty Lariat
AFE Stage II Cold Air Intake
PHP Tunes , Autometer Gauges
Zoodad Mod,
4"SS MBRP Exhaust
ITP Overboost Annihilator
Roada Deco Positive Air Shutoff
NADP Heavy Hauler Transmission
6 liter Trans Cooler
Diesel Site Coolant Filtration System
dusted4eva is offline
post #6 of 11 Old 12-17-2010, 05:17 PM
Have one use it for the most part in reading the temperatures of the intake air, transmission, ECT and EOT in Arizona heat these are critical to know when it is 120+
Can be set up to display 4 readouts showing at one time
For highway running the manifold boost pressure, the live MPG and the ECT / EOT
The 07 has factory dash transmission and ECT gages but are just a if reading mid point are it is in factory approved area for operating, the Scangage shows the movement up climbing a grade and the dropping back down on the down side live some of the other add on seem to have issues with power feeds and grounds in getting good readouts
Has some 15 or more possibly points that are taken from the onboard computers controlling the truck Thinking your alternator is not working to high voltage cooking the batteries or to low not keeping them up and slow hard starts you can see what it doing as you drive
post #7 of 11 Old 12-21-2010, 09:05 AM Thread Starter
Tranny is back in and working...
The factory replacement cooler is about 2/3 larger than the one I pulled off the truck. Seems they know they have a problem there.
As for the ScangaugeII, it looks like the tranny temp is under the Xgauge feature. But it isn't listed in the 7.3 l diesel section, just under the Ford PWM. PWM? DieselFord, you are using one to monitor tranny fluid temps in your 7.3?
MarkBMC is offline
post #8 of 11 Old 12-21-2010, 03:47 PM
PWM.. pulse width modulation. The torque converter is modulated on in a 3 phase time frame.
ipz2222 is offline
post #9 of 11 Old 12-28-2010, 04:11 AM Thread Starter
errrr... does that have anything to do with a flux capacitor? Sorry... in my mind an automatic transmission (and the torque convertor) operates with secret words and magic dust.
MarkBMC is offline
post #10 of 11 Old 12-28-2010, 04:23 AM
My truck is a 2007 with 6.0 Did you enter the script and see if it works ? Try it.
