alright this is not easy to explain but from a dead stop 1st gear will wind out to 3000 rpms before shifting into 2nd, but when it does shift into 2nd almost everytime it will fall right into 3rd. i tried to start in 2nd from a stop but once again it will stay in first and once it gets to 3000 r's it does a "double" shift and goes right into 3rd. just did an oil change that really didnt go as planned because all i really did was drain the pan then over filled it so i drained out the extra fluid to a good level and it did absolutely nothing to fix my problem. everybody tells me that the shift solenoid is messed up but i cant seem to find that to fix it, so i would really like for some help diagnosing the problem or finding the solenoid, i have a 2000 f-250 xlt 7.3L diesel with the 4r100 tranny, its a daily driver so i would really like some help with this
yes i have tried that when i shift it into first wont shift until 3k if i try to from 2nd its actually in first and double shifts into 3rd gear and seams to skip 2nd altogether shifts into 3rd and 4th no probs at all
Put it in park and crawl under the truck. Make sure the lever on the trans is as far back as it can go. Also, look at your range sensor, there are two alignment marks on it, when you are in neutral, the alignment marks will line up too. Make sure your emergency brake is on and the truck is off! Safety first.
Time to go deeper. You will need to pressure test it and watch to see if you have a cross leak or leak then during that shift. Leaking check ball, feed bolts, vb gaskets, ect...
No, you need a oil pressure gauge with a range up to 300 psi. The test port is the little plug in front of your lever. Don't be tempted to use one that is not rated for that kind of pressure.
I would pressure test it like I said earlier, but Im thinking it is slipping and thats why when you let off it catches.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
