Manual Trans Problems Here
Since there isn't a lot of knowledge about manual transmissions, this should be a stickied thread.
Feel free to edit this as necessary. PROBLEM: LOW CLUTCH PEDAL SOLUTION 1: Add/ Bleed Hydraulic Assy. Takes DOT3 brake fluid. SOLUTION 2: Fix/ Repair Clutch Rod linkage bushing. Ford part # E69Z7526A SOLUTION 3: New Master and/Or Slave Cylinder. PROBLEM: HARD TO SHIFT TRANSMISSION SOLUTION 1: Add/ Bleed Hydraulic Assy. Takes DOT3 brake fluid. SOLUTION 2: Fix/ Repair Clutch Rod linkage bushing. Ford part # E69Z7526A SOLUTION 3: New Master and/Or Slave Cylinder. SOLUTION 4: Replace Clutch Fork SOLUTION 5: Replace Clutch Assy. (Includes clutch, pilot and throwout bearings, and pressure plate, may require machining flywheel) SOLUTION 6: Rebuild transmission PROBLEM: WILL NOT SHIFT Refer to above two points PROBLEM: WILL NOT MOVE/STRANGE NOISES SOLUTION 1: Replace clutch SOLUTION 2: Rebuild transmission |
Looks like I am going to be going after problem #3, hopefully only step 1 for the solution. How difficult is it to pull one of these trannies? I ask, because I HAVE to have this truck back up and running ASAP and if I can do it myself I may. I might just drop it off at a shop too and have them tear into it... Its my work truck and I'm on call 24/7/365 so this is going to bite me in the ***. I guess thats what I get for working for the only company in the oil field where I put on 6,000+ miles a month and they don't provide a company truck! DAMNIT, I'M SCREWED!!!
