Drive Engaging Problem - Ford Powerstroke Diesel Forum
Old 11-02-2010, 05:43 PM
Ok so I have spent a few hours trying to search this and havent found and exact issue like mine.
When I first start the truck after sitting for more then an hour or so, The truck will go into drive but not move. If i rev it up to about 1200-1500 sometimes it will engage other times nothing. If I let the truck idle for about 10-15 min there is no problem engaging. Also if I start the truck and hold the RPM's at 1000 for a min or two the tranny will engage fine. Does anyone have a straight answer for me?
The tranny shop I called said maybe the "drain back valve" or the pump. Im not super worried about, if it goes it goes, but Im about to make a 5000 mile round trip next month (not towing anything) and dont want it going half way through the trip.
Old 11-02-2010, 05:46 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
bad torque converter \, change fluid clogged trans filter or cooler. bad bypass valve, bad trans pump, bad mlps sensor.
Old 11-02-2010, 05:50 PM
Forgot to mention, its benn doing this for about a week. Changed the fluid and filter in the tranny. Fluid still looked good and no bad smell. Also this is just my daily driver truck. I do not tow anything with it besides a few cases of beer on the weekends.
Old 11-03-2010, 05:41 PM
Ck the fluid level before starting the eng in the am. Should be not more than 1 inch above the full mark. If it is more than that, the fluid is draining back out of the converter. If it has been rebuilt before, it may have a modification that creates full time lube. Not a bad thing but annoying. My truck has it and if it sets for 4 days, it won't even move when I first start it up. I just let it idle for 20 seconds and the tc fills up and it goes right into gear.
Other wise, trans is worn out.
Old 11-03-2010, 06:08 PM
Heres an update. Took it to the transmission shop today and all of my forward clutches are burnt up. $2300 for a rebuild and new torque converter. Comes with a 2yr/24000 mile warranty, not too bad I guess. Thanks for all the input
Old 11-14-2010, 09:56 AM
dmd dmd is offline
NOt a bad price, but if it ever needs it done again you could have had a BTS or John Woods... Then you would have had a real transmission!!
