4R100: Reverse only
Acquired this truck relatively cheap but with one issue. It's a late '99 F-250 2wd with 150k miles and a solid running engine but the transmission will not shift into any forward gears. It positively shift into reverse without any problem. Fluid appears clean/unburnt and I am going to try to get a code reader tomorrow to see what it's throwing. Has anyone had a similar problem and what was the diagnosis? Thanks in advance!
Is there a selonoid pack on these transmissions I am not sure but her is a bump for you
yes, theres a selenoid pack
I have the same issues over here in the UK, if I give it some gas in drive it starts to creep forward, but in reverse it's fine!
Foward clutches burnt..
Update: Borrowed a code reader from Autozone and got no codes from their reader. Might get something from a better reader but nothing at this point.
You may not get any codes. I also think something wrong with forward clutch/drum.
This happened to a friend and his 00 F250. Forward clutch packs were done. The solution was a BTS transmission.
