Name that failing part! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-17-2010, 02:06 AM Thread Starter
kitchene's Avatar
I got my 2000 f550 in July. 226k on the clock, no record of tranny rebuild, I knew it would need to be done.
Last week I was driving alone and the OD light starts flashing for nothing obvious. Still shifted fine, sounded fine. Took her home, shut her down. Next day, same thing happened in about the same time frame, about 2 miles down the road, OD light flashing. Hoping to verify the issue, I unhooked the batteries to clear everything thinking if it's really starting to die, it'll with do it again. It does not, so I'm thinking whew and bullet dodged for now.
2 days ago, drove to the jobsite. My dad was there and his truck had a trailer on so he used my truck to run home. He gets back, doesn't say anything about shift problems, and I have to leave. a mile down the road I notice it's not going into OD. I'm getting that sick gut feeling knowing whats happening. Had a half quart of fluid in the back so I added it.
From there It doesn't shift into OD, it slips, it kind of makes a grumbling sound going down the road in drive. Taking off from a stop it made a grinding sound that sounded like the rear end went out even.
So I ask, is that the TQ, something a rebuild will fix, or something worse?
The fluid smells scorched now. There are no leaks, and about 3 weeks ago i did a quick fluid change. just dumped what was in the pan and put in some new to top it off. I did have about 1/4 cup of fine metal shavings on the mag in the pan.
So yes, I knew it was due, but I didn't think it would all go at once. In the past every trans I've experienced die did it slowly....
Thanks
Kitchene
1997 F350 SRW CCLB 4x4 XLT 7.3, ZF5, bone stock but not for long.
2000 F550 2WD CC Cab/Chassis PSD (in progress)
DIY Intake with AEM dry cone filter, ZooDad, AIH Delete, Foil Removed, Superchips Flashpaq, Mobile Delvac.
1988 F800 toy... Dozer hauler.. for sale.. 7.8L inline 6, 6sp Trans, 2sp diff
kitchene is offline
post #2 of 4 Old 10-17-2010, 04:32 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
when mine didnt go into OD, and i started having huge heat issues, it was the shift Solenoid pack that went bad. They are about 350-400 bux from ford. REALLY easy to put it in. its right there under the pan. has about 10 bolts in it holding it in, and a wiring plug on it.
change all your fluid. its toast.
Im not saying thats your problem, BUT, if you could get it on a GOOD code reader(Matco, MAC, ECT), you can read your tranny codes(flashing OD light means there is a code). that will def tell your problem.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 4 Old 10-17-2010, 06:28 AM Thread Starter
kitchene's Avatar
where did you get the solenoid at?
Kitchene
kitchene is offline
post #4 of 4 Old 10-17-2010, 06:30 AM Thread Starter
kitchene's Avatar
Nevermind, from Ford. It's early!
Kitchene
kitchene is offline
