Coast Brake 4R100 - Ford Powerstroke Diesel Forum
post #1 of 17 Old 10-01-2010, 12:02 PM Thread Starter
Fishhook240's Avatar
Coast Brake 4R100
How can I turn off the coast brake on my 4R100 trans. Would like to be able to turn it off/on when ever I want. The harness diagram shows a red wire that controls the solenoid and I was wondering has anybody installed a switch on that wire and if I did would it throw a code or affect the trans.
1999 f350 4R100
Live as if it was your last Day!!! "AMEN"
Fishhook240 is offline
post #2 of 17 Old 10-01-2010, 12:04 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Coast brake?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 17 Old 10-01-2010, 12:05 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
are you talkin about when you let off the gas when in od and it winds down before it unlocks? and injectors are off/ not firing?
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #4 of 17 Old 10-01-2010, 12:33 PM Thread Starter
Coast Brake
Yes I would like to turn it off so the truck would drive better and save fuel Any help!!!
post #5 of 17 Old 10-01-2010, 01:11 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
generally the injectors are already off. its the transmission thats spinning the engine when the tq is locked.
Sold
LSP Group Threads
Jarrod B is offline
post #6 of 17 Old 10-01-2010, 01:37 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
A locked converter gives better MPG's
No reason to want to unlock it while cruising
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 17 Old 10-01-2010, 01:56 PM Thread Starter
I think we are talking about two different things. I'm talking about the coast brake not the locking torqe converter Two different things. When you are going about 55 and let off the gas the truck will slow down rapidly. I looked up the info for that trans (4r100) and it has a coast brake that is doing it. It is solenoid controled and the wiring diagram says it is a red wire and if i put a switch in it will it mess up the trans or throw a code I want to turn it off/on when I want to
post #8 of 17 Old 10-01-2010, 02:38 PM Thread Starter
I'm sorry but it's called a coast clutch and it is controled by the CCS. I am trying to get the trans to freewheel when I let off the gas/diesel
post #9 of 17 Old 10-01-2010, 02:47 PM
dannanw's Avatar
Quoted: 62 Post(s)
Garage
I just put mine in neutural, say when I am going down a hill and dont want to slow down.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #10 of 17 Old 10-01-2010, 02:52 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
It slows rapidly because your converter is locked at that speed. It will unlock if you let out of the pedal and it gets below 45 mph.
Get a custom chip with an econo tune. Thats the only way to achieve what you want
Email:
Edge Insight CTS
Coolant filter
Dave is offline
