how hot does your trans temp get - Ford Powerstroke Diesel Forum
Old 06-27-2010, 01:28 PM
i have an 01 7.3 have had since it was new. i have a lawn company and pull trailers from 5k to 10k. the orginal trans would never get over 200. no matter how you drove it. had to swap trans at 100,000. the trans i put in would run 240 or higher a lot. it only lasted 30,000. now i am on trans #3 and it still runs 240 on the highway emty. i have exhaust, 38r turbo, edge evo. both trannys had billet backed convertors and bd diesels acummulator bodies. any help would be awsome thanks. also sometimes the trans temp doesnt get over 220. i have tried aftermarket coolers and it doesnt matter. how hot do your trucks run. thanks
Old 06-27-2010, 01:34 PM
PMR = JUNK
One problem could be the edge.
Old 06-27-2010, 01:44 PM
im am ordering a dp tuner f5 on tuesday. i hate this edge with the new turbo it just dosent run smooth at all
Old 06-27-2010, 01:50 PM
PMR = JUNK
I would recommend Total Diesel Performance (TW), Swamps, Beans, or PHP for tuning.
Old 06-27-2010, 01:52 PM
get that dp tuner in there and get a 6.0L cooler
Old 06-27-2010, 01:53 PM
are they that much better than dp
Old 06-27-2010, 01:54 PM
people have their preference, I like my Dp a lot. the only reason i dont like other tuners is the stupid little knob type switch they give you.
Old 06-27-2010, 01:55 PM
so what makes a 6.0l cooler so good, are they better than a aftermarket cooler
Old 06-27-2010, 01:57 PM
the reason its so good is because of its size, they are like 135% bigger than a 7.3L cooler. Also i would maybe replace your bypass valve on the trans.
In 100 degree weather driving in stop and go traffic my trans temp get to a max of 165 degrees.
Old 06-27-2010, 02:03 PM
PMR = JUNK
DP tuner likes playing with timing too much. Advancing it too far, causing high cylinder pressures, which leads to broken connecting rods.
