? about Lucas.....
I heard Lucas was good for slipping. WHEN is it too late to put it in? I had a flush bout 2k miles ago.......thanks in advance if ANYone is even around..
I happened to be out of town when the light for the over drive began flashing, and the trans was having trouble going into second gear. The RPM were up around 3500/4000 before it would switch. I ended up taking it to a large Ford dealership near Gettysburg PA and having it diagnosed. Here is what the tech wrote on the invoice.
"Test drove vehicle, completed transmission diagnostics, retrieved multiple fault codes from computer including, incorrect gear ratio and 1-2 shift error, transmission has internal problem and would need to be overhauled or replaced, advised customer that vehicle should not be driven until repair is complete." All the cost me $139.95. They wanted $3800.00 for a trans installed but couldn't do it till mon or tues, which my schedule didn't allow. I ended up draining enough fluid so I could put in 36oz of Lucas trans fix. I just made the 400mi nonstop trip from Pa to OH with an improvement in shifting. The truck shifted as normal. I will still be seeing a local mechanic in the morning to have the problem further looked at as I think the Lucas was a temporary fix. It did save me a tow bill though. |
Lucas didn't work for me, but I think it was just too late. I had an injector fail and it caused a vibration that started to shake the torque converter apart. By the time I tried the Lucas it was too late and my tranny was overheating very badly and slipping in and out of gear constantly. I was told by the tranny shop that the pump began to fail also, which I can't see Lucas helping at all once it starts to go.
thanks for the input. I had heard that it helps to keep things smoother. I guess I will try it to hopefully help it work smoother for now. Not having issues, but a little preventative maint never hurts
