changing out the OD switch - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-19-2010, 05:27 PM Thread Starter
HRS PLY's Avatar
anyone done this. Mine worked fine on the test drive. got it home and it didn't want to work much. Now it wont turn on the light at all and wont lock out OD. I can bet it just wore out but I have never changed one.
thanks in advance
Michael
2000 F350 CC SB exhaust and PHP Tune
HRS PLY is offline
post #2 of 3 Old 05-23-2010, 10:01 PM
Easy. there is a small plastic ring on the end of the stalk. Use a knife blade to pry it off. now grab hold of the light assy and pull it out. If it still doesn't work after you replace it, the wires are broken inside the shifter. New shifter is about $68.
ipz2222 is offline
post #3 of 3 Old 05-24-2010, 01:50 PM Thread Starter
HRS PLY's Avatar
thanks for the info...........
HRS PLY is offline
