2001 pilot bearing problem - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-09-2010, 09:56 AM Thread Starter
Quoted: 4 Post(s)
I have two 350's with 6 spds. (99 & 01)
Both have had the tans. out in past month . The
pilot bearings were all to pieces in both . Is there a solution or
upgrade for this problem . I have had one trans rebuilt because of the worn input shaft . And the other one needed a shaft but I have to
keep one truck operating . The 6.0 trans has a bigger input but the
motor don't seem to last long from everyone I've met with one .
mcgoo
mcgoo422000 is offline
post #2 of 6 Old 05-09-2010, 10:09 AM
ford_trck's Avatar
Send a message via AIM to ford_trck
I put in a kevlar pilot bearing from South bend clutch and haven't had any problems since.
Early 99 F-350 CC LB 6-speed
Stock with mods
Originally Posted by CloverLeafFarm View Post
Hey Ross, after talking with you i did some research and seems like you chose the right path to go, i knew you were a super genius!
Ross
ford_trck is offline
post #3 of 6 Old 05-09-2010, 11:08 AM Thread Starter
Quoted: 4 Post(s)
I looked up the south bend site . did you just use the pilot bearing
or buy a whole clutch kit ? The clutches they have look like the
800 and up variety . I got 175,000 out of the first clutch and
98,000 out of second one . i'm thinking the shaft was worn some and let it flop a litle causing the pilot problem . The input had some end play too . I have had the trans rebuilt already cost 1350.00
but just about all parts were replaced and want it to last as long as possible . Hotshoting in kind of hard on a truck anyway .
I'm always at least 18,000-33,000 gross weight . One truck has 375,00 on it other has 259,000 . So I've been expecting some repairs about now . The last clutch was dealer kit the funny thing I bought a autozone kit and it had same name on disc and was 200 cheaper this most recent one . Couldn't complain I was in anderson SC in holiday express parking lot doing it . I still like the 7.3 and 6spd .
mcgoo
post #4 of 6 Old 05-09-2010, 07:15 PM
99BEIGEPOWERSTROKE's Avatar
Just wondering how did you know the pilot bearing was going bad? Any signs of it going to bad to look for?
1999.5 FORD F250 SUPERDUTY 4X4 EXT CAB
7.3L POWERSTROKE DIESEL
6 SPEED
SWAMPS 175/146 SINGLE SHOT INJECTORS
SWAMPS TUNING
6" AUSSIE STACKS
AFE INTAKE W/ PRO GUARD 7 FILTER
VAN TURBO
4" SUSPENSION LIFT
315/75/16 BUCKSHOT MAXXIS MUDDER TIRES ON STOCK WHEELS (WINTER TIRES)
16X9 MOTO METAL 951 BLACK WHEELS (SUMMER)
COWL HOOD
99BEIGEPOWERSTROKE is offline
post #5 of 6 Old 05-09-2010, 07:38 PM Thread Starter
Quoted: 4 Post(s)
The sign was the truck quit moving foward . I was clicking about 65
down I 85 S and it went zing that was it , till I installed a new clutch
mcgoo
post #6 of 6 Old 05-09-2010, 08:06 PM
ford_trck's Avatar
mcgoo
I installed a 550hp clutch and everything because I put a chip in the truck and the stock clutch wouldn't hold the power on my high setting. You can get the pilot bearing by itself you just have to call and ask. I have 36,000 on my clutch and just pulled my engine and the pilot still looks good.
Stock with mods
Ross
