6 speed noise in first. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-23-2010, 09:40 PM Thread Starter
Im looking at buying a 2000 f250 6 speed. I found a local truck with 125k but when i took it out for a test drive i could here and feel a grinding noise after letting the clutch out in first, it disapears after a second or two. I aslo think i herd it a little noise in second gear too.
Is this normal?
if not what will this thing cost to get fixed?
Or should i just walk away and keep looking.
Thanks for the help guys.
Dave_78337 is offline
post #2 of 5 Old 05-04-2010, 02:55 PM
FFFORD's Avatar
I just bought a 2000 7.3 with 140k on the ticker. The noise you are hearing I believe is normal. I searched for this issue on this website and there is another post explaining why/what it is but i cant seem to find it now. from what i remember however, (i could be wrong) the driveshafts are 2 piece and rattle at low RPMs. you can actually do it in any gear if you are at very low RPMs i believe. my 2000 does it most noticeably in 1st and second gears. I believe you can take it to a driveshaft garage and they can Shim it accordingly to stop the noise.
try a search, see if you can find it. I know the thread is on this website, i just cant find it now.
FFFORD is offline
post #3 of 5 Old 05-04-2010, 03:07 PM
dalton1's Avatar
that nose is normal, every ford with a manual I have driven including my old truck make that noise when first accelerating.
03 F-250 Lariat Crew Cab SB 6.0L Auto 4x4
5" exhaust, AFE intake, Blue spring mod, EGR Delete, 58v FICM, Warren 175/75 injectors, Powermax Turbo,
ARP Head Studs, Coolant filter, Innovative tunes
Pine Tree Powerstroke Association Director
pm me for chapter info
dalton1 is offline
post #4 of 5 Old 05-04-2010, 04:52 PM
smokin95psd's Avatar
Send a message via AIM to smokin95psd
it is refered to as gear rattle. All big trucks do it if they have a solid flywheel. The OBS trucks had dual mass flywheels and it quieted the noise but the flywheels sucked. After a few miles ( my buddy has one with 55,000 nad it does it.) the springs give away and it is noisier and shakes vigerously. Any way the noise is normal. No worries. ( P.S. I had a 1995 powerstroke 5 speed and now have a 2002 powerstroke 6 speed.)
smokin95psd is offline
post #5 of 5 Old 05-04-2010, 05:11 PM
O.I.F. Combat Vet 11B
every standard I have ever driven has made noises in first gear at slow speeds.
2000 f250 crew cab 4x4 6sp manual, Jim Rosewood 238/100 hybrids, gtp 38r, srp1.1 hpop, DP-Tuner! Driven diesel fuel sys!
269,xxx and counting!!
ju015dd is offline
