No power in reverse?
when i put my truck in reverse and back up it seems to bog out? any suggestions why its doing this. auto trans by the way
Does it ever kill the eng>???
the engine does not totally die out but it gets close...
You have a cross leak in the pump trying to apply the lockup converter. The pump has higher pressure in reverse so that is when it first shows up. Sometimes it will do it in fwd if the trans is real hot.
how would i diagnose/ fix this problem. im not really experienced with transmissions so any advice would be good.
Ferrt difficult to diagnose without experience. Watch you tach when you put it into fwd . Note how far down (rpm) it drops. Then do reverse. it should be the same. If it drops further and even further as you very slightly touch the throttle, that's a pretty good indication of the tcc trying to come on.
okay is it the front pump or is it TC that is the problem and is this a full trannie rebuild or just replace pump or TC?
Miles on truck?????
sorry bout changing the subject. but i have a question about my tranny . i am doing some work on my truck and i will be at 600 hp and 1000pds torque can i get by with just a sun coast converter or do i have to get whole new tranny ? 06 truck 5r100 auto tranny .
Topdollar. you need to go to the '03 up 6.0 forum. You have a different eng and trans than what is discussed here.
