HELP! Clutch wont dissengage! - Ford Powerstroke Diesel Forum
Old 04-18-2010, 02:41 PM
I have a 2000 f350 super duty manual transmission with about 64k miles on it and some light modifications (exhaust, intake, light chip). Earlier today i was towing my fifth wheel and pulled over and the clutch wouldn't fully disengage. I yanked it out of gear to get it to stop. I got it to shift (very roughly) and limped it home (only about 20 freeway miles). By that time, the clutch was completely engaged all the time. I had to turn the truck off to get it to stop. Is this the slave cylinder or the clutch itself? If i do need a new clutch which one would you recommend? Any suggestions would be greatly appreciated.
Old 04-18-2010, 03:40 PM
I just had the exact same thing happen to me.
My clutch decided to puke up one of its' springs.
Old 04-18-2010, 03:54 PM
shaking things up
could be slave cyl. look at the reservoir if it has fluid it is most likely your clutch
Old 04-18-2010, 05:25 PM
Ya there is plenty of fluid
Old 04-19-2010, 06:44 AM
shaking things up
it might be the ghetto bushing they used look under the dash at the connection the links the pedal to the rod.
Old 04-19-2010, 06:46 AM
shaking things up
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners check this out for a possible fix i know alot of ppl dont like him on here but this is the best fix out there bar none and this is a good vid of how to do it
