trans temp? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-14-2010, 06:05 PM Thread Starter
USMC97stroker's Avatar
Send a message via AIM to USMC97stroker
trans temp?
02 7.3 auto, wondering what is the max trans temp you want to see before you start damaging the trans?
97' F-250 PSD
4" rough country suspension lift
6 position chip w/ custom tunes
DIY K&N cold air intake
5" mitre cut stacks
swamps 150/146 single shot injectors
USMC97stroker is offline
post #2 of 15 Old 04-14-2010, 06:17 PM
Raul@Stealth Automotive's Avatar
over 210... i wouldnt go any higher than that
Raul@Stealth Automotive is offline
post #3 of 15 Old 04-15-2010, 09:28 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
IMO 180*
Automatic Transmission Fluid Temperature
Automatic transmission fluid (ATF) has a life of about
100,000 miles at 175*F. At high temperatures, it oxidizes,
turns from red to brown and exhibits a burnt smell. In
addition to reducing the oil’s lubricating quality, high
temperature produces a varnish on internal parts
interfering with the operation of the transmission. Above
250*F., rubber seals harden, leading to pressure loss and
leaks. Also, the transmission can slip. In the worst cases,
clutches fail and costly repairs result.
ATF manufacturers suggest that for every 20*F. increase
in operating temperature above 175*F., the life of the fluid
is cut in half. Hence at 195*F., oil life will be about 50,000
miles. Above 240oF., it becomes nil. Without adequate
coolingwilllikely push the ATF operating temperature very high.
CT Performance, Inc. is offline
post #4 of 15 Old 04-15-2010, 09:32 AM
Hate stupid people
CloverLeafFarm's Avatar
Quoted: 139 Post(s)
at one time i had my tranny temp at 255*, and it scared the crap out of me....once i got home i let it idle for awhile to cool it down and parked it until the next day
Illiana Strokers DICtator
EFI Live tuned 6.7
CloverLeafFarm is offline
post #5 of 15 Old 04-16-2010, 05:49 AM
the witchdoctor's Avatar
Sorta a dumb question guys, but if the fluid goes back to the radiator and is cooled at the same temp as the motor, would the temp not be close to 195 ?
THE WITCHDOCTOR
(sold) 2001 F250 xcab 4x4,Steel cowl hood, Leveling Kit, S&B, Eagle 18x10,285/70/17 Kelly TSR's,A/C Mod, Isspro EV2's, Foil Delete,Banks Big Head, TS 6 pos chip/Tyrant Tunes,BTS valve body,Stancor Mod, 4" exhaust
the witchdoctor is offline
post #6 of 15 Old 04-16-2010, 05:59 AM
The transmission has its own cooler, it sits IN FRONT of the radiator and gets the cool air before it hits the radiator, unlike the "old days" when the fluid was routed into the radiator...
ffstreetdoc is offline
post #7 of 15 Old 04-16-2010, 09:14 AM
redwoody's Avatar
actually, I can't speak for all F-series SD's with the 4R100, but ATF 'IS' routed into the lower tank of the engine radiator (of my '02) prior to being routed to it's very own cooler between the engine radiator and intercooler.
2002 F-250 7.3PSD, Lariat, 4x4, CC, SB, AT
-ISSPRO Guages (pyro, trans, boost) on pillar
-TW 6 Pos Chip
-4" Magnaflow
-DIY Cooling System Filter
-Custom Built Transmission and 3-disc TC
-ATS Ported Turbo Housing
-CCV Delete
-Donaldson DIY Intake
-AIH Delete
-6.0L Transmission Cooler
-6.0L Intercooler
-Zoodad intake mod
-Pro Comp 2" leveling kit
-Pro Comp Crash Bar
-Firestone Air bags
-full syn blinker fluid
redwoody is offline
post #8 of 15 Old 04-16-2010, 04:51 PM
The trans cooler in the radiator goes into the coolest part of the water. Tha water may be as low as 140&. I wan't to see trans temp from 140 to 180 on normall operation. An occasional 200 or 220 while pulling a heavy load is ok, but not for very long.
ipz2222 is offline
post #9 of 15 Old 04-16-2010, 04:56 PM
Other vehicle is an F250
Hank's Avatar
Actually the fluid is sent to the radiator to warm it up in the winter. Ideal temp for our transmissions is 150 or so I have been told. The cooler in the front is to cool it when it is hot.
The fluid is recirculated within the transmission until it reaches 100 degrees. This is to help it warm up faster.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #10 of 15 Old 04-17-2010, 04:52 PM
redwoody's Avatar
the best way I have found to keep my tranny cool is to work the engine! get those revs up. if you climb a steep grade...say a gravel mountain road with a trailer, you might want to consider puttin the rig in 4 low, 1st or 2nd. that way, you will get higher revs and can use engine braking on the down hill side. you don't want to coast at 1000 rpms or the tranny temps will soar. air flow is key too of course.
-TW 6 Pos Chip
-4" Magnaflow
-CCV Delete
-AIH Delete
-6.0L Intercooler
-Zoodad intake mod
-Pro Comp Crash Bar
-Firestone Air bags
redwoody is offline
