I need help with my tranny its going crazy - Ford Powerstroke Diesel Forum
Old 03-28-2010, 06:49 PM
I was having problems with my truck, it would not go into forward gears but would go in reverse anywahere i wanted it to. I put it on a computer and said that the temp. sensor was bad. I change the temp sensor and now i have all my forward gears but will not go in reverse, pull forward in all gears even reverse now. And it will put forward in park when reved up.put it back on the computer to day and i says that the speed sensor is bad. Will this cause the prob that im having.
Old 03-29-2010, 04:17 PM
some one please help
Old 03-29-2010, 04:32 PM
Heres a for ya
Old 03-30-2010, 06:05 PM
having the same problem. my truck wont go forward in d,2,or1st but will go into reverse. says speed sensor,im getting one tomorrow but it doesnt sound right:-(
Old 03-30-2010, 07:47 PM
350man. Where and how did you change the temp sensor?? Did you have any of the valve bodies off,,, linkage??????
Old 03-31-2010, 03:14 AM
no ive not done anything with the tranny just took the pan off and new fluid and filter. i Took the pan back of today and i have took the truck like 10 miles burt fluid and filter cloged agian
Old 04-02-2010, 02:52 PM
If the filter is clogged in 10 miles, tranny is gone.
