Solenoid problems?
I'm thinking I may need to replace my torque converter solenoid. Been having some intermittant issues and did some research here and the symptoms point to this.
I have a hard shift sometimes into OD and sometimes it seems to hang on quite a while before shifting. Today I drove about 3 miles at 65 mph, around 2100 rpms with out shifting into OD. then, before it shifted the RPMs bounced up 200 or so a couple of times then it shifted. I scanned for codes and nothing showed but... I can't find a write up for this process, can anyone help me out? Can I reuse the tranny fluid I'll have to drain? It's new fluid, had it changed out 300 miles or so back. Hate to replace it at the cost.... Thanks! Last edited by MtPaul401; 03-19-2010 at 11:38 AM. |
![]() ![]() any one? |
I would think your TC selenoid has nothing to do with it not shifting into OD, but I could be wrong.....as far as the fluid, if you can drain it and keep it meticulously clean, I don't see why not
Just had the fluid changed 3000 miles ago or so and the shop said the pan was fine, no more crud than normal.
At what speed should it shift into OD? Ususlly I get a shift around 45-50 if I'm not accelerating too hard, but sometimes it hangs on until 55-60 before shifting. |
Heavier loads mean later shifting. Lack of eng power, later shifting. Solenoid problems are a verrrrrryyy rare thing. I'd be looking somewhere else first. You need a scanner that can read the data to see if the computer is commanding the shift at the proper time.
Can I test the solenoid while it's still in the tranny? What resistance am I looking for ?
Forgot to add that I have the Banks transcommand module too...would this have anything to do with it?
The solenoids are on the bottom of the list for any complaints. They are hardly ever the problem. All the solenoids are together in a block. If any one is bad the whole block must be replaced.
Shifting into lockup or shifting into od. Very hard to tell which one is happening. This is the easiest way and you don't have to have a scanner. Cancel od. In your mind say "first gear" , press the throttle about 1/4 down, as soon as it shifts say, 2nd, as soon as it shifts, say 3rd, as soon as it shifts say 4th. When you reach 55 to 60 mph, cancel od. You should feel one more shift. That will be OD. |
