Shifting too early!!!!!
What controls the shift points PCM or throttle potentiometer or what?
What do I check......this will roast the high gear clutches in a hurry? Help!!! |
tps,throttle position sensor, vss, vehicle speed sensor, ect, engine coolant temp sensor, brake switch.
How early??? Way early means the computer thinks it's in 4wd. |
It will be in high gear before I can make it through a red-light. So what do I do break down and take it to Ford???
If you don't have a good local trans shop available.
Trans shop (performance transmission) tells me with their scanner that every thing is working properly that it is just getting the signal from the PCM too early.
That is correct. It thinks it's in 4wd low. I've never seen the problem but have heard others haveing it.
Wow thats crazy. Look for a PCM from a local yard with matching numbers. Or take it to ford and have them re flash it for 95 bucks...
PCM matching numbers purchased and on the way. I also have a P0605 (Rom Error) DTC code. I thought the truck might have been chipped or something. I pulled the PCM....took the cover off and no evidence of anything.....all silicone present and everything. I should receive it by thursday......I'll keep everyone posted.
(took the cover off, no evidence of anything) . '96 up computers are not 'chipped' anymore. They are reprogrammed thru the diagnostic connector.
Any up dates on this? I've got a truck that does the same thing.
