Clutch pedal clicking on engagement stroke - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-31-2010, 02:57 PM Thread Starter
SaskBigGreenMachine's Avatar
Heard a brand new noise today as I got into my truck and fired it up. As I released the clutch pedal from taking the truck out of gear to allow it to warm up, I heard and felt this clicking noise/feeling come from the clutch pedal. So I got under the dash and started depressing and releasing the clutch pedal to find out where the clicking was coming from. I notice that on releasing the pedal I can see the master cylinder moving just a little away from the fire wall on the release stroke and as it is released you can hear, see and feel something clicking inside. It makes no noise or clicking on the depress stroke, only when I engage the clutch on the up stroke. Just wondering if there is a retainer clip that holds the master to the firewall that could have broke or could the clutch position sensor be going and need replaced or do I need to look at a new master cylinder? I'm stumped !!!
E99 7.3L F-250 XLT Crew Cab Longbox
Wild Country LT285/75/R16
Wicked Wheel
CCV Relocation Mod
Tymar DIY Intake
Custom Fab Intake Setup
4" T-Back AFE Exhaust w/ IDP 5" SS Tip
EBPV Delete (Pedestal and Turbo Exhaust Housing)
Dieselsite Adrenaline HPOP
140V IDM Mod (75k, 1/2watt, 1%)
Dac3 ECM
Purple CAM position Sensor
Line-X Bedliner
Autometer Gauges
Gotta get new sticks and deciding on a chip.
The Rest ---> Stock for now
SaskBigGreenMachine is offline
post #2 of 3 Old 03-25-2010, 10:06 AM
First Post.... long time lurker... and by no means a mechanic...
OP did u get this resolved?
I have the same problem. From what i saw under the dash is that there is a sensor that sits on top of the Master Cylinder. This sensor is what makes the clicking in my truck (I believe its purpose is to ensure the clutch is depressed prior to starting the engine). From what I have read elsewhere it seems that there is a retainer clip inside the master that keeps the pedal from coming all the way up near the near the access panel under the steering wheel. This clip wears out and then the pedal proceeds to spring further and further up towards the dash. As this happens that sensor becomes looser and looser and starts clicking. This is where I have been at for a month or so. I am just used to keeping my foot on the clutch all the time to prevent the pedal from springing all the way up to the dash.
On this and other forums peoples suggestion seem to be to get a new "pre-bled" master slave kit. I have called three different dealerships here in so-cal looking for this pre-bled kit with no luck everyone is willing to sell me the master for around 100 and the slave for 70.
While bleeding the hydraulic system does not appear too involved it is something i would rather not do. I wish there was just a bleed screw on the slave.
tl;dr. Master is shot. Bleeding the system is difficult. Any aftermarket alternatives? or sealed kits?
RichWT is offline
post #3 of 3 Old 03-25-2010, 10:57 AM
Just found this. my local stealership wondries ford has 2 in stock and claim they are 250 bucks.
Originally Posted by SCUFFY828 View Post
part number 2C3Z-7C522-A, AND ROD NEEDED IS 6C3Z-2143-BA, tel them to get you those if you decide to do that
RichWT is offline
