Attention all tranny guys - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-28-2010, 04:40 PM Thread Starter
I have a 99 auto, pulled the motor, the TC fell out of tranny and got some snow in it, 2 weeks later put motor back in, drained the TC and put in new fluid. Started the truck, put it in gear and i have no forward or reverse gears. The trucks idle changes when put into gear but there is no power being transfered to the wheels. If anyone can help i would be very thankful!
brady7.3 is offline
post #2 of 16 Old 01-28-2010, 04:43 PM
duct tape & zip ties
bigcountrysg's Avatar
Are you sure you have the tc completed seated. If it is not completed seated into the trans. Then that can cause your problem.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 16 Old 01-29-2010, 04:21 AM Thread Starter
Would it leak tranny fluid if it was not seated, and would the tranny be able to mate up with the motor all the way if that was the case. Because it is completely assembled.
brady7.3 is offline
post #4 of 16 Old 01-29-2010, 04:42 AM
djh
djh's Avatar
It probably wouldn't leak if the converter is not fully seated into the pump of the transmission as the transmission is probably not building pressure and the sealing surface on the converter is also long enough to provide a proper seal.
It is possible to bolt the transmission to mate up to the motor with the converter not properly seated, this can cause damage and I would take it apart and check everything out.
Silly question...I know you said the converter has fluid in it, but does the transmission have proper level in it?
6637 DIY Filter
4R100 w/ Transgo Tugger and billet converter.
ISSPRO boost, trans, EGT on A-pillar.
DP-Tuner F5 chip: Stock, hi-idle 1200 rpm, 60 tow, 80 tow, decel, 60 eco, 80 eco, 100 performance, 120 race, 140 extreme, 140 aggressive
Wicked Wheel
djh is offline
post #5 of 16 Old 01-29-2010, 01:41 PM
If you did't have the converter fully seated when you put the eng back in, you've broke the pump gears. VERY COMMON problem. I'm assumeing you put the converter back in the trans before you reinstalled the eng. ?????
ipz2222 is offline
post #6 of 16 Old 01-31-2010, 05:59 AM Thread Starter
Yes the converter is in the trans, yes the tranny has propper fluid level. The transmission is pumping just fine, i pulled the high pressure test port and it sprayed like crazy! I pulled the input shaft sensor and used a mirror to c inside to c if i could c something rotating but there was no movement! So i pulled it last night hoping it was not in all the way or something, but i could not tell, so anybody have anymore insight on the deal?
brady7.3 is offline
post #7 of 16 Old 01-31-2010, 11:12 AM
I'm assumeing the trans was working before you pulled the eng???
Here's a list of no fwd or rev causes. Broken pump( spraying fluid out pressure port, pump good), tc dampner broke, broke intermediate shaft, rolled over input sprag ( Did you try manual low, if this was the problem it would have pulled in man low), low fluid.
ipz2222 is offline
post #8 of 16 Old 01-31-2010, 11:19 AM
Reinstall the tc make sure it is fully seated. Then reinstall the trans. Then check the fluids, then try to move the truck.
Yes it is possible to damage something. How ever it is also possible to not have damage anything too.
The trans may or may not leak with the tc not fully seated. Being if the tc is in the trans far enough it will obtain a seal around the input seal.
2002 7.3L burnt
post #9 of 16 Old 01-31-2010, 11:19 AM
Let me rephrase something. Fluid spraying out the pressure port does not necessarily mean pump is good. You could have jammed the pump enough to cause low pressure, not enough to apply the clutches but enough to flow fluid out the pressure port. Most of the time , people break the pump gears and no flow at all. Look at the converter where th flat spots are, right at the outer edges. Do they look like they have been squished in. Was the tc a little hard to remove from the trans??
ipz2222 is offline
post #10 of 16 Old 01-31-2010, 04:58 PM Thread Starter
Reinstalled the tranny, but i ran out of tranny fluid, so i dont know if it works yet. The converter looked ok, but when i drained the fluid i thought i would shake it and when i did i could here something moving inside. Is that bad? The plug that i had pulled sprayed like crazy just when the engine cranked!
brady7.3 is offline
