Stick to auto - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-26-2010, 08:11 PM Thread Starter
Stick to auto
How hard would this be to do... will everything line up like the transfer case?
I am guessing I would need flex plate, converter, trans cooler, and lines.
There is a 6 speed truck that I am looking at and am wondering if stick to auto can be done without to much cost and customization.
Wickky is offline
post #2 of 5 Old 01-26-2010, 08:40 PM
Send a message via MSN to Rockstar Edition Send a message via Yahoo to Rockstar Edition
it's very possible to do. there are MANY GUYS on here that would love to do this swap with you...hell if youre close enough and my original guy doesnt have time Ill swap with you, I want a 6 speed in my truck.
Chad
Rockstar Edition is offline
post #3 of 5 Old 01-26-2010, 08:51 PM
THEE RAT's Avatar
i have a 6 speed truck and love it!! i had a auto b4 this.. the best for towing and having a little fun!
SOLD - 02 F350 CC LB DRW 6 speed 2wd
SOLD - 01 F350 CC LB 12inch lift on 24's and 38's
SOLD - E99 CC DRW 2wd 6 speed
TRADED IN THANK GOD! - 2005 DODGE 2500 CC SB
CURRENT-2005 CC DRW 2wd!
THEE RAT is offline
post #4 of 5 Old 01-31-2010, 11:44 PM
danno676's Avatar
What did you need to do the swap? I'm about to be on tranny number 5 and have HAD IT!!!
I know the obvious:
trans
flywheel
clutch
pedal assy
master/slave and lines
Did you need to do computer? crossmember? adapter to xfer case? output shaft on std trans same as auto?
Thanks
2002 F250 SD 7.3 Crew Cab Short Bed that is oh so stock
Sold
2001 F250 SD 7.3
Banks Big Hoss, Banks 6 gun, Banks intercooler
Turbonetics turbo
Precision LOW stall convertor
and lots more
danno676 is offline
post #5 of 5 Old 01-31-2010, 11:55 PM
danno676's Avatar
I found this:
Auto to Manual Converstion
Sold
2001 F250 SD 7.3
Turbonetics turbo
and lots more
danno676 is offline
