Transmission Dummy - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-21-2010, 01:33 PM Thread Starter
Keanan's Avatar
Question Transmission Dummy
I have a 2001 PSD with the 4R100 auto trans. I have a edge programmer giving it 80 ponies or so. My trans slips like crazy shifting from first to second, and again from third to fourth. IF I drive like a grandma it will short shift and shift hard. I assumed since I have 240,000 miles on my truck that it was probably too much power for the worn out stock torque converter so I replaced it with the Banks tc and trans command they suggested. After spending 1300 bucks on the parts and a few hours of my labor, the change.... nothing. Once it slips and finally shifts it will actually bark the tires. I have done some searching online and found some insight that it could be the solenoid block. Does this sound correct? If so where can I find one that isn't used? Any help would be greatly appreciated.
Keanan is offline
post #2 of 8 Old 01-21-2010, 01:44 PM
shaking things up
jethro's Avatar
try getting rid of the edge first they are know to be terrible for trannies and the banks trans command and get custom tuning from one of the many out there TW, DP, SWAMPS, ect.... that should help your problem as they will actually control your tranny much better
389.14 HP 726.00 TQ
96 f-350 7.3 with a 5 speed
3 in DP
4 in ex. to 5 in aussies
custom traction bars
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
custom fuel with an AIRDOG 2
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
facebook- Graham Maxwell
jethro is offline
post #3 of 8 Old 01-21-2010, 01:45 PM
shaking things up
jethro's Avatar
btw where you from?
389.14 HP 726.00 TQ
3 in DP
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
jethro is offline
post #4 of 8 Old 01-21-2010, 01:49 PM Thread Starter
Keanan's Avatar
Thanks for the friendly welcome!
I am originally from Missouri, but my job took me to the Chicago area. BTW, I put the edge in it to try to keep it from slipping. I used to have a superchips programmer and it slipped as well. My transmission buddy back home said it was just my tc locking up. The edge was supposed to increase the shift firmness. I have a buddy up here that has a 2001 with a bullydog and he is willing to let me borrow it to see if it makes a difference so maybe I will try your idea.
Thanks again.
Keanan is offline
post #5 of 8 Old 01-21-2010, 01:51 PM
Quoted: 5 Post(s)
mine does the same thing. I need a rebuild........
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #6 of 8 Old 01-21-2010, 02:44 PM
shaking things up
jethro's Avatar
np this site is FULL of helpful info if you dig deep enough or post up what you need it may need a rebuild but if you just had it out the tc is know good correct? if so i would have them check the clutches and install a shift kit in it if you can
389.14 HP 726.00 TQ
3 in DP
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
jethro is offline
post #7 of 8 Old 01-21-2010, 07:33 PM
No way a tc can cause a slip in 2nd or 3rd. 240,000 miles and you start adding horsepower??? Not a good idea. Go ahead a get your trans rebuilt before you destroy the new tc. fyi.... Most trans shops will not warranty a rebuilt trans unless it has a new converter. Not a new cconverter that has already been run in a slipping trans.
ipz2222 is offline
post #8 of 8 Old 01-23-2010, 12:03 AM
DJM
DJM's Avatar
When I had my edge it seemed to slip also I just put in My DP tuner and it doesn't seem to slip anymore. The edge did it only when I got on it though if I just drove around normal it was fine.
2001 Crew Cab, Auto
6in lift, 37Toyo's
DP F6 60eco,80tow,80eco,120
Wicked Wheel
Foil Delete
Isspro EV2 Guages
HPX Line
RiffRaff FRx
4" Exhaust
AFE Big Boost
FS 2500 Filter
DJM is offline
