4r100 pouring fluid - Ford Powerstroke Diesel Forum
post #1 of 20 Old 01-14-2010, 04:21 PM Thread Starter
Blowin Smoke
firemedic355's Avatar
4r100 pouring fluid
I just got done installing my new 4r100 and now it's pouring fluid from somewhere in the bellhousing. The install seemed to go without a hitch. I made sure the Torque Converter was pushed all the way back on the shaft and even pushed the tranny flsuh up to the motor by hand to make sure it went on smooth.
After the install I put in 13 qts (I'd top it off once it was warm) let it idle to get warm, then started shifting between the gears to check the feel of everything. It all felt and sounded good, but after about a minute it started pouring a steady stream from somewhere in the bellhousing. I'm gonna look into more in the morning, but anyone have any ideas for now?
99' F250 Ext Cab Flatbed 4x4
EDGE Juice w/ Attitude
Cowl Hood
Warn 12000 winch
Warn hubs
Billet Grille
DPF Delete
CCV Mod
4" lift w 35's
5" black single stack
firemedic355 is offline
post #2 of 20 Old 01-14-2010, 05:03 PM Thread Starter
Blowin Smoke
Anybody?
Cowl Hood
Warn 12000 winch
Warn hubs
Billet Grille
DPF Delete
CCV Mod
4" lift w 35's
post #3 of 20 Old 01-14-2010, 05:06 PM
duct tape & zip ties
bigcountrysg's Avatar
Either pump seal, or front input seal. I would bet on the front input seal as it is easy to damage that when you install the torque converter.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #4 of 20 Old 01-14-2010, 05:08 PM Thread Starter
Blowin Smoke
How hard is it to replace? And is it a dealer only item?
Cowl Hood
Warn 12000 winch
Warn hubs
Billet Grille
DPF Delete
CCV Mod
4" lift w 35's
post #5 of 20 Old 01-14-2010, 05:11 PM
Depends if it is the pump seal or the input seal.
Input seal is able to be picked up at any parts store. To replace it you have to remove the trans. Then remove the torque converter. Then remove the old seal. Then install the new seal and reinstall the torque converter, and then install the trans again.
2002 7.3L burnt
post #6 of 20 Old 01-14-2010, 05:18 PM Thread Starter
Blowin Smoke
Which seal is it exactly? This is my first time doing an automatic tranny.
Cowl Hood
Warn 12000 winch
Warn hubs
Billet Grille
DPF Delete
CCV Mod
4" lift w 35's
post #7 of 20 Old 01-14-2010, 05:26 PM
When you remove the torque converter there is a seal behind it. This seal keeps fluid in the trans. If it goes bad or is damaged, then it will leak around the shaft of the torqu converter.
2002 7.3L burnt
post #8 of 20 Old 01-14-2010, 05:44 PM Thread Starter
Blowin Smoke
I'm still not 100% sure on which one it is. Is it on the input shaft? Is it a ring seal or an Oring?
Cowl Hood
Warn 12000 winch
Warn hubs
Billet Grille
DPF Delete
CCV Mod
4" lift w 35's
post #9 of 20 Old 01-14-2010, 05:47 PM
AutoZone.com | | Transmission Seal | SEAL
That is the one you most likely need.
2002 7.3L burnt
post #10 of 20 Old 01-14-2010, 05:54 PM Thread Starter
Blowin Smoke
Cool, thanks!
Cowl Hood
Warn 12000 winch
Warn hubs
Billet Grille
DPF Delete
CCV Mod
4" lift w 35's
