Clutch
Ok I have a slight vibration in the floor of truck. It is there when truck is sitting idling or moving. If I push clutch in it goes away. I am thinking throwout bearing or I read something about clutch fork. What is the clutch fork and how do I check it? If the throwout bearing or clutch fork is going bad will it cause any problems?
None of those can be checked without pulling the trans. You probably have a broken dampner spring in the flywheel or clutch.
from what I'm told, you'll only hear a bad throw out bearing if the clutch is engaged. mine makes a rattleing sound untill the clutch is engaged, had a few people including a reputable trans shop listen to it and was told it was a bad input bearing in the trans. I'm told it'll be ok to ignore it, and at the price of a new/rebuilt tranny it'll stay as is for now.
I just noticed mine started doing this last weekend. I was told it could possibally be the Dual Mass flywheel
Will a broken dampner spring hurt anything? The clutch and flywheel and bearings are only like 12000 miles old. I cant really hear a noise but just feel the vibration. It does go away at times to. But it does it most of the time.
My trans is also rebuilt with like 6000 miles on it.
couldnt help ya man
