First post! Been lurking a long time gaining knowledge..you guys have been a big help.
Troubleshooting transmission issue. We think it is loose feeder bolts. Got everything off except the solenoid pack.
Had to drop exhaust and heat shield to get better access to the clip on top of housing. Took pic so I could see how the clip worked.
First attempt and the tab broke off! I tried screwdriver in tab, two tiny screwdrivers in front and behind whats left of the tab.
I am stuck. How do I get this thing off!
Attached some before and after pics. I tried cleaning it a little to see what I had.
Would like to keep it even with broken clip since it seems to have no problem staying connected!
If I cant salvage I'll probably pigtail a new one because replacing whole harness or repinning is to tough in that area.
