Trans problem! - Ford Powerstroke Diesel Forum
Old 11-27-2009, 08:48 AM
Send a message via Yahoo to spdjnky_42
Trans problem!
I have an 02 SD w/ an auto. Couple days ago going around a turn it shifted to 2nd. It was a mean hard shift not loose just hard. The next day it was wanting to go but not keeping up w/ the rpms in the same gear. Seems to be a low rpm problem, if I let off then gas it it takes right off. Then yesterday, it started flashing the OD light on the shifter arm. Any ideas? Also, I changed the fluid and filter about 5000 mi ago at 130,000 and added an SCT programmer, but have not been abusing the truck. All of these problems occured w/ in 50 miles. Thanks in advance.
Old 12-11-2009, 02:44 PM
Not sure I understand your description of the problem. "won't keep up with the rpm's". Since you have a flashing od light, you have a code stored, get it checked.
