please help me tranny problems - Ford Powerstroke Diesel Forum
Old 11-18-2009, 05:08 PM
Feedback Score: 3 reviews
I have a 2002 f250 7.3 diesel 4x4 with automatic transmission, i just got it rebuild at this local shop here in daytona beach florida , i went for a test drive and when i take off takes till 3000rpms to shift and shift hard but only in 1 and 2 gears, i check the fluid and is good and them the OD light start blinking if i give gas easy it would shift smoostly the jackass a the shop wont wanna check it it says is my truck that have problems now i am screw with over $2000 on it , anyone have an idea what can be the problem thanks
Old 11-18-2009, 05:53 PM
Tranny has to relearn shift patterns according to Ford. Mine did something similar after change out for a few shifts and then straightened out. If doesn't and shop won't stand behind their work then file complaint with BBB and a copy of that complaint to consumers division state attorney general
Old 11-18-2009, 06:04 PM
Send a message via MSN to dusted4eva
Yeah what he said and get yourself an ATS or BTS tranny
Old 11-18-2009, 06:15 PM
Lifetime Premium Member
Mine did the same thing.All is good now.Give it a little time.If it still gives you trouble,make them stand behind there product.
Old 11-18-2009, 08:58 PM
Yup the computer is used to old loose clutches and has the pressure ramped way up. When it sees the shift is happening too fast it will drop the pressure a tiny bit for the next shift. It can take 100 cycles like this for it to get it right if it has good performance clutches in it.
Old 11-19-2009, 02:58 AM
but i drove 281 miles and still doing same i am going to put the scanner today and see what codes come up...the shop that rebuild it wont do anything for me i know the guy i got all the parts and i pay him cash for the labor
Old 11-19-2009, 11:33 AM
Did they do any shift mods or a shift kit? Sounds like they may have drilled an orifice out a bit and it's B/S that they won’t help you with it! If they drilled it you may be able to change the valve springs and/or valves to bring it back. That takes knowledge I don’t have since I have never done it, but if you want to fix it yourself these guys will have the parts and I think will walk you through it.
PATC contact info
E4OD/4R100/5R110 parts page
Old 11-19-2009, 04:42 PM
i dont think he did a shift kit on it i am taking the truck tomorrow to get codes i dint have time today.....
Old 11-21-2009, 02:12 PM
here are the codes P0733 INCORRECT GEAR 3 RATIO ,,,,,P0781 1-2 SHIFT ERROR,,,, AND P1249 WASTEGATE CONTROL VALVE
Old 12-11-2009, 03:11 PM
""The guy that built it, I pay him cash and I buy the parts.""
There's your problem. You got what you paid for.
