O/D light flashing and funney shifting tranny - Ford Powerstroke Diesel Forum
post #1 of 27 Old 11-04-2009, 08:45 PM Thread Starter
Well, i went for a drive around the block in my 2001 F350.
Going up a street the o/d light started to flash, I slowed down to stop, but the transmission felt like it wanted to keep driving, it didn't seem to want to disengage, so I coasted up the street, and the o/d light stopped flashing, and the tranny allowed me to stop.
Driving home it seemed to shift OK, but my imagination is telling me the truck feels a little rough thru the floor, i'e a vibration.
Typically when the truck is cold it's very reluctant to shift up a gear. If it's revving 2000+, and i take my foot off the pedal the revs will drop, and when I press the pedal gently the revs will rise to 2000+, in otherwards it doesn't want to upshift at low rpms on light throttle. After a mile or two it will shift OK and hold a gear at lower rpm's (I may not be describing that very well)
The other part that's funny is that if I'm coasting down a hill in Overdrive, the engine revs will drop down to 600rpm, I can only get engine breaking with overdrive disengaged, or when I'm in a lower gear. I'm not sure if it's supposed to do that (my GMC 1500 doesn't do that!)
I've had the truck for 2 weeks, it has 146k miles, and has been very well looked after and is in mint condition. Maybe i've just found out why the guy wanted to sell the truck.
Thanks in advance for any help
Dave
2001 F350 auto
ts 6 position chip
AFE cold air intake
4 in pro-comp lift
triumph406 is offline
post #2 of 27 Old 11-04-2009, 08:51 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
hmm. the only thing that should be done is pull the codes from the transmission or go to a transmission shop and have them pull codes and go from there.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 27 Old 11-04-2009, 09:04 PM Thread Starter
That's what I have planned, Saturday is probably the earliest I can get it done.
post #4 of 27 Old 11-04-2009, 10:25 PM
adfields's Avatar
What year and trans, 4 or 5 speed?
Sounds from the cold shifting and mileage it needs a flush and filter.
The not wanting to stop sounds like the converter lock up sticking which could also be from crap in the fluid sticking the valve. I would start with pulling the codes and a service unless the codes show something counter indicating, meaning it would just waste the new fluid.
The lack of engine braking is normal when driving in OD, it should brake like your Chevy when you cancel OD. I hate the lack of engine braking but both my Fords do it and always have, one is a 95 e4od 4 speed and the other is a 01 EX with the 5 speed.
ANDY
My baby is a one of a kind.
1977 I bought a new 76 F150 club cab.
Sitting on a 84 F350 6.9 4X4 chassis
With all the drive train and goodies from a 95 4X4 4door PSD.
Nothing stock left on her and not a nut, bolt, hose, or wire on there that I didn't put where it is.
The Wifes Ride:
2002 Excursion Limited 7.3 PSD
Themo King/Mikuni coolant heaters on both to keep things toasty without idling.
adfields is offline
post #5 of 27 Old 11-05-2009, 05:41 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
he has the 2001. so 4speed
Sold
LSP Group Threads
Jarrod B is offline
post #6 of 27 Old 11-05-2009, 08:05 AM Thread Starter
I'll be at the local tranny shop Saturday morning to see what the codes are. I hope it doesn't mean a new tranny, and is something simple.
the lack of engine bracking in OD to me is a major PITA, around here there's some long hills I coast down, and having to shift out of OD to get engine braking is a pain.
Dave
post #7 of 27 Old 11-05-2009, 12:28 PM
adfields's Avatar
Most likely in a 350 but I have the 5r110 5 spd behind a 7.3.
ANDY
The Wifes Ride:
adfields is offline
post #8 of 27 Old 11-05-2009, 01:43 PM Thread Starter
From the factory?
post #9 of 27 Old 11-05-2009, 01:59 PM
adfields's Avatar
Originally Posted by triumph406 View Post
From the factory?
Yup completely stock, wife won’t let me mod 'her' EX.
ANDY
The Wifes Ride:
adfields is offline
post #10 of 27 Old 11-05-2009, 03:02 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
holy crap man. thats just weird. in that case, i want one!!!!!!!!!!!!!!!!!
Sold
LSP Group Threads
Jarrod B is offline
