will v10 trans work for 7.3? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-25-2009, 11:39 AM Thread Starter
fas_guy's Avatar
I've been trying to find a trannie for my 2000 4x4 7.3 and i found a guy localy parting out a 01 excursion with a v10 in it but I don't know if they are the same please help me the v10 is 2wd also
fas_guy is offline
post #2 of 2 Old 10-26-2009, 02:50 PM
adfields's Avatar
Keep shopping friend, I believe the bell housing bolt pattern is different and I know the tail housing/output shaft from a 2X4 won’t work in a 4X4. You must take the Trans all the way down to swap the shaft so you would be ahead to rebuild what you have if you have it all apart.
ANDY
My baby is a one of a kind.
1977 I bought a new 76 F150 club cab.
Sitting on a 84 F350 6.9 4X4 chassis
With all the drive train and goodies from a 95 4X4 4door PSD.
Nothing stock left on her and not a nut, bolt, hose, or wire on there that I didn't put where it is.
The Wifes Ride:
2002 Excursion Limited 7.3 PSD
Themo King/Mikuni coolant heaters on both to keep things toasty without idling.
adfields is offline
