I have a 2wd 4r100 going into an E350. I think i have a trans from an F series because the output shaft does not have the worm gear for the speedometer. Can I use the F series speed sensor in an E series? If not, how hard is it to swap output shafts? I do alot of mechanic work but have only cracked open an automatic transmission once, and that was to re-torque the feed bolts.
I'm doing exactly the opposite and already had the output shaft changed but still cannot get 3rd or o.d. of light flashes after I drive a few miles with no code from my programmer I checked all connections, new vss new output shaft sensor..I'm a newbie to diesels and don't know all the abbreviations or much about them at all but learning quick. I would appreciate deeply any help for my 01 f250 7.3 thanks
Sent from my 5056W using Tapatalk
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
